From 90 HP from 4.1 liters to 651 NM from 7.0 liters…everything is here. The wide engine range leaves nothing to be desired. Cruiser or „heavy-foot“, there should be something for everyone.
1968 | ||||||
| Engine | Horsepower | Torque | Carburetor | Compression | Bore & Stroke | VIN Code |
| 200-1V I-6 | 115 hp (86 kW) @ 3800 rpm | 190 lb·ft (257 Nm) @ 2200 rpm | 1-Venturi | 8.80:1 | 3.68" x 3.13" | T |
| 289-2V Windsor V8 | 200 hp (150 kW) @ 4400 rpm | 288 lb·ft (390 Nm) @ 2400 rpm | 2-Venturi | 8.70:1 | 4.00" x 2.87" | C |
| 302-2V Windsor V8 | 210 hp (160 kW) @ 4400 rpm | 300 lb·ft (407 Nm) @ 2600 rpm | 2-Venturi | 9.00:1 | 4.00" x 3.00" | F |
| 390-2V FE V8 | 265 hp (198 kW) @ 4400 rpm | 390 lb·ft (529 Nm) @ 2600 rpm | 2-Venturi | 9.50:1 | 4.05" x 3.78" | Y |
| 390-4V FE V8 | 325 hp (242 kW) @ 4800 rpm | 427 lb·ft (579 Nm) @ 3200 rpm | 4-Venturi | 10.50:1 | 4.05" x 3.78" | S |
| 427-4V FE V8 * | 390 hp (290 kW) @ 5600 rpm | 460 lb·ft (624 Nm) @ 3200 rpm | 4-Venturi | 10.90:1 | 4.23" x 3.78" | W |
| 428-4V FE V8 ** | 335 hp (250 kW) @ 5600 rpm | 445 lb·ft (603 Nm) @ 3400 rpm | 4-Venturi | 10.70:1 | 4.13" x 3.98" | R |
| * Listed as an option, but no cars produced with this engine ** Mid-year option |
1969 |
| 250-1V I-6 | 155 hp (116 kW) @ 4000 rpm | 240 lb·ft (325 Nm) @ 1600 rpm | 1-Venturi | 9.00:1 | 3.68" x 3.91" | L |
| 302-2V Windsor V8 | 220 hp (160 kW) @ 4600 rpm | 300 lb·ft (407 Nm) @ 2600 rpm | 2-Venturi | 9.50:1 | 4.00" x 3.00" | F |
| 351-2V Windsor V8 | 250 hp (190 kW) @ 4600 rpm | 355 lb·ft (481 Nm) @ 2600 rpm | 2-Venturi | 9.50:1 | 4.00" x 3.50" | H |
| 351-4V Windsor V8 | 290 hp (220 kW) @ 4800 rpm | 385 lb·ft (522 Nm) @ 3200 rpm | 4-Venturi | 10.70:1 | 4.00" x 3.50" | M |
| 390-4V FE V8 | 320 hp (240 kW) @ 4600 rpm | 427 lb·ft (579 Nm) @ 3200 rpm | 4-Venturi | 10.50:1 | 4.05" x 3.78" | S |
| 428-4V FE V8 * | 335 hp (250 kW) @ 5600 rpm | 445 lb·ft (603 Nm) @ 3400 rpm | 4-Venturi | 10.70:1 | 4.13" x 3.98" | Q ** |
| * Available with Ram Air Induction option ** VIN code 'R' with Ram Air |
1970 | ||||||
| 351-2V Cleveland V8 | 250 hp (190 kW) @ 4600 rpm | 355 lb·ft (481 Nm) @ 2600 rpm | 2-Venturi | 9.50:1 | 4.00" x 3.50" | H |
| 351-4V* Cleveland V8 | 300 hp (220 kW) @ 5400 rpm | 380 lb·ft (515 Nm) @ 3400 rpm | 4-Venturi | 11.00:1 | 4.00" x 3.50" | M |
| 429-4V 385 Series V8 | 360 hp (270 kW) @ 4600 rpm | 480 lb·ft (651 Nm) @ 3400 rpm | 4-Venturi | 10.50:1 | 4.36" x 3.59" | N |
| 429CJ-4V 385 Series V8 * | 370 hp (280 kW) @ 5400 rpm | 450 lb·ft (610 Nm) @ 3400 rpm | 4-Venturi | 11.30:1 | 4.36" x 3.59" | C ** |
| 429SCJ-4V 385 Series V8 * | 375 hp (280 kW) @ 5400 rpm | 450 lb·ft (610 Nm) @ 3400 rpm | 4-Venturi | 11.30:1 | 4.36" x 3.59" | C ** |
| * Available with Ram Air Induction option ** VIN code 'J' with Ram Air Cleveland has 8-bolt valve cover, Windsor has a 6-bolt valve cover. That´s the easiest way to describe the difference. |
1971 | ||||||
| 250-1V I-6 | 145 hp (108 kW) @ 4000 rpm | 232 lb·ft (315 Nm) @ 1600 rpm | 1-Venturi | 9.00:1 | 3.68" x 3.91" | L |
| 302-2V Windsor V8 | 210 hp (160 kW) @ 4600 rpm | 296 lb·ft (401 Nm) @ 2600 rpm | 2-Venturi | 9.00:1 | 4.00" x 3.00" | F |
| 351-2V Windsor V8 | 240 hp (180 kW) @ 4600 rpm | 350 lb·ft (475 Nm) @ 2600 rpm | 2-Venturi | 9.00:1 | 4.00" x 3.50" | H |
| 351-2V Cleveland V8 | 240 hp (180 kW) @ 4600 rpm | 350 lb·ft (475 Nm) @ 2600 rpm | 2-Venturi | 9.00:1 | 4.00" x 3.50" | H |
| 351-4V Cleveland V8 * | 285 hp (213 kW) @ 5400 rpm | 370 lb·ft (502 Nm) @ 3400 rpm | 4-Venturi | 10.70:1 | 4.00" x 3.50" | M |
1972 | ||||||
| 250-1V I-6 | 98 hp (73 kW) @ 4000 rpm | 183 lb·ft (248 Nm) @ 1600 rpm | 1-Venturi | 8.00:1 | 3.68" x 3.91" | L |
| 302-2V Windsor V8 | 140 hp (100 kW) @ 4000 rpm | 239 lb·ft (324 Nm) @ 2000 rpm | 2-Venturi | 8.50:1 | 4.00" x 3.00" | F |
| 351-2V Windsor V8 | 153 hp (114 kW) @ 3800 rpm | 242 lb·ft (328 Nm) @ 2000 rpm | 2-Venturi | 8.30:1 | 4.00" x 3.50" | H |
| 351-2V Cleveland V8 | 161 hp (120 kW) @ 4000 rpm | 276 lb·ft (374 Nm) @ 2000 rpm | 2-Venturi | 8.60:1 | 4.00" x 3.50" | H |
| 351CJ-4V Cleveland V8 * | 248 hp (185 kW) @ 5400 rpm | 299 lb·ft (405 Nm) @ 3600 rpm | 4-Venturi | 8.60:1 | 4.00" x 3.50" | Q |
| 400-2V 335 series V8 | 172 hp (128 kW) @ 4000 rpm | 298 lb·ft (404 Nm) @ 2200 rpm | 2-Venturi | 8.40:1 | 4.00" x 4.00" | S |
| 429-4V 385 Series V8 ** | 205 hp (153 kW) @ 4400 rpm | 322 lb·ft (437 Nm) @ 2600 rpm | 4-Venturi | 8.50:1 | 4.36" x 3.59" | N |
| 429-4V 385 Series V8 *** | not listed | not listed | 4-Venturi | not listed | 4.36" x 3.59" | P |
| * Available 2-door models only, Ram Air Induction optional ** Ram Air Induction optional *** Available with police "Interceptor" package only Cleveland has 8-bolt valve cover, Windsor has a 6-bolt valve cover. That´s the easiest way to describe the difference. |
1973 | ||||||
| 250-1V I-6 | 88 hp (66 kW) @ 3200 rpm | 196 lb·ft (266 Nm) @ 1600 rpm | 1-Venturi | 8.00:1 | 3.68" x 3.91" | L |
| 302-2V Windsor V8 | 137 hp (102 kW) @ 4200 rpm | 230 lb·ft (312 Nm) @ 2200 rpm | 2-Venturi | 8.00:1 | 4.00" x 3.00" | F |
| 351-2V Windsor V8 | 156 hp (116 kW) @ 3800 rpm | 234 lb·ft (317 Nm) @ 2200 rpm | 2-Venturi | 8.00:1 | 4.00" x 3.50" | H |
| 351-2V Cleveland V8 | 159 hp (119 kW) @ 4000 rpm | 250 lb·ft (339 Nm) @ 2400 rpm | 2-Venturi | 8.00:1 | 4.00" x 3.50" | H |
| 351CJ-4V Cleveland V8 * | 246 hp (183 kW) @ 5400 rpm | 312 lb·ft (423 Nm) @ 3600 rpm | 4-Venturi | 8.00:1 | 4.00" x 3.50" | Q |
| 400-2V 335 series V8 | 168 hp (125 kW) @ 4000 rpm | 310 lb·ft (420 Nm) @ 2000 rpm | 2-Venturi | 8.00:1 | 4.00" x 4.00" | S |
| 429-4V 385 Series V8 | 198 hp (148 kW) @ 4400 rpm | 320 lb·ft (434 Nm) @ 2800 rpm | 4-Venturi | 8.00:1 | 4.36" x 3.59" | N |
| 460-4V385 Series V8 ** | 269 hp (201 kW) @ 4600 rpm | keine Angabe im Prospekt | 4-Venturi | 8.80:1 | 4.36" x 3.85" | C |
| * Available 2-door models only ** Available with police "Interceptor" package only Cleveland has 8-bolt valve cover, Windsor has a 6-bolt valve cover. That´s the easiest way to describe the difference. |
1974 | ||||||
| 302-2V Windsor V8 | 140 hp (100 kW) @ 3800 rpm | 230 lb·ft (312 Nm) @ 2600 rpm | 2-Venturi | 8.00:1 | 4.00" x 3.00" | F |
| 351-2V Windsor V8 | 163 hp (122 kW) @ 4200 rpm | 278 lb·ft (377 Nm) @ 2000 rpm | 2-Venturi | 8.20:1 | 4.00" x 3.50" | H |
| 351-2V Cleveland V8 | 162 hp (121 kW) @ 4000 rpm | 278 lb·ft (377 Nm) @ 2000 rpm | 2-Venturi | 8.00:1 | 4.00" x 3.50" | H |
| 351CJ-4V Cleveland V8 * | 255 hp (190 kW) @ 5600 rpm | 290 lb·ft (393 Nm) @ 3400 rpm | 4-Venturi | 7.90:1 | 4.00" x 3.50" | Q |
| 400-2V 335 series V8 | 170 hp (130 kW) @ 3400 rpm | 330 lb·ft (447 Nm) @ 2000 rpm | 2-Venturi | 8.00:1 | 4.00" x 4.00" | S |
| 460-4V 385 Series V8 | 220 hp (160 kW) @ 4000 rpm | 355 lb·ft (481 Nm) @ 2600 rpm | 4-Venturi | 8.00:1 | 4.36" x 3.85" | A |
| 460-4V 385 Series V8 ** | 260 hp (190 kW) @ 4400 rpm | 380 lb·ft (515 Nm) @ 2700 rpm | 4-Venturi | 8.80:1 | 4.36" x 3.85" | C |
| * Available in 2-door models only, not available in Gran Torino Elite ** Available with police "Interceptor" package only Cleveland has 8-bolt valve cover, Windsor has a 6-bolt valve cover. That´s the easiest way to describe the difference. |
1975 | ||||||
| 351-2V Windsor V8 | 143 hp (107 kW) @ 3600 rpm | 255 lb·ft (346 Nm) @ 2200 rpm | 2-Venturi | 8.20:1 | 4.00" x 3.50" | H |
| 351-2V Modified V8 | 148 hp (110 kW) @ 3800 rpm | 243 lb·ft (329 Nm) @ 2400 rpm | 2-Venturi | 8.00:1 | 4.00" x 3.50" | H |
| 400-2V 335 series V8 | 158 hp (118 kW) @ 3800 rpm | 276 lb·ft (374 Nm) @ 2000 rpm | 2-Venturi | 8.00:1 | 4.00" x 4.00" | S |
| 460-4V 385 Series V8 | 216 hp (161 kW) @ 4000 rpm | 366 lb·ft (496 Nm) @ 2600 rpm | 4-Venturi | 8.00:1 | 4.36" x 3.85" | A |
| 460-4V 385 Series V8 * | 226 hp (169 kW) @ 4000 rpm | 374 lb·ft (507 Nm) @ 2600 rpm | 4-Venturi | 8.00:1 | 4.36" x 3.85" | C |
| * Available with police "Interceptor" package only | ||||||
1976 | ||||||
| 351-2V Windsor V8 | 154 hp (115 kW) @ 3400 rpm | 286 lb·ft (388 Nm) @ 1800 rpm | 2-Venturi | 8.00:1 | 4.00" x 3.50" | H |
| 351-2V Modified V8 | 152 hp (113 kW) @ 3800 rpm | 274 lb·ft (371 Nm) @ 1600 rpm | 2-Venturi | 8.00:1 | 4.00" x 3.50" | H |
| 400-2V 335 series V8 | 180 hp (130 kW) @ 3800 rpm | 338 lb·ft (458 Nm) @ 1800 rpm | 2-Venturi | 8.00:1 | 4.00" x 4.00" | S |
| 460-4V 385 Series V8 | 202 hp (151 kW) @ 3800 rpm | 352 lb·ft (477 Nm) @ 1600 rpm | 4-Venturi | 8.00:1 | 4.36" x 3.85" | A |
| 460-4V 385 Series V8 * | 226 hp (169 kW) @ 3800 rpm | 371 lb·ft (503 Nm) @ 1600 rpm | 4-Venturi | 8.00:1 | 4.36" x 3.85" | C |
